Export to IFC Area Missing
arunsan.9846m
Message 1 of 10
arunsan.9846m
Room/space area are not getting exported in IFC Reference view set
Replies (9)
Message 2 of 10
benschilders
I am no expert on IFC at all but maybe try this option:
pyRevitHave a look at my idea: Material priority Revit quick start guide ┃Please accept soulution if my anwser solved your problem
Message 3 of 10
arunsan.9846m
it's till the same
Message 4 of 10
benschilders
1. check or IFC mapping is correct:
1.1 file > export > options > IFC options:
2. check this option: (Use 2D room boundairys...)
Result: (the green is the room volume in 3D)
PS: i also had the other settings from my first anwser active, only export elements from 3D view and export rooms in 3D
EDIT:
I might be good to also check this setting:
Message 5 of 10
arunsan.9846m
hi good morning
I tried but still the same
Message 6 of 10
arunsan.9846m
I think its because of Revit 2023. when I export in Revit 2020 the area is getting exported
Message 7 of 10
Which IFC standard did you use to export?
Message 8 of 10
arunsan.9846m
see the different between Revit 2020 and 2023 Ifc output
Message 9 of 10
arunsan.9846m
and I'm using IFC4
Message 10 of 10
arunsan.9846m
Am using IFC4
