Read value from a parameter and use it in a Filter Rule
Haider_of_Sweden
Haider_of_Sweden
This is what I did:
  • Project Paramtet named "Isolate This" for View
  • I created a Filter that looks into Comments to create a rule from the value typed there
  • I now want to read the value typed in under "Isolate This" parameter and use it inside a Filter Rule, see screenshot
Is it possible?
benschilders
1. The parameter you are showing us is from a view not from the categorie doors
2. You should add the Ïsolate this"parameter to the filter not comments
So try using the same category and the same parameter (project or shared) in the filter.
Soulution:
1. make isolate this parameters fillable for doors: ( Manage -> project parameters -> select -> modify -> check doors)
2. Fill the parameter from some door instances.
3. edit your filter and change comments to your own parameter.
4. Add the filter to views/viewtemplates as desired and make sure to set
the parameter to not visible
pyRevitHave a look at my idea: Material priority Revit quick start guide ┃Please accept soulution if my anwser solved your problem
Haider_of_Sweden
@benschilders - sorry, I seem to have been unclear with my first post.
I have two parameters, and I want them to "talk to each other".
Please see the steps I have taken
1) Manage > Project Parameters:
I create a parameter for Views. I only want to type in things in views.
2) I have elements in my scene with comments
3) I now want to create a filter, that reads whatever I have typed in this view's Parameter which I called "Isolate this"
How do I read whatever is written under the view-specific parameter "Isolate This" and use it inside a view filter?
Is there any syntax that does this?
L.Maas
No this is not how it works.
You get something like "All Selected" from "Isolate this" "equals" (or contains etc) and then enter a value (e.g Beta).
If needed you can expand by using the and/or function.
You get something like "All Selected" from "Isolate this" "equals" (or contains etc) and then enter a value (e.g Beta) AND "Comments" "equals" value.
You can not do something like "Isolate this" is equal to "Comments"
If you want something like comparing "comments" to "isolate this" then you probably need to do some scripting (e.g Dynamo).
Louis
Please mention Revit version, especially when uploading Revit files.
Haider_of_Sweden
Thanks Louis,
Too bad. It would've been a cool thing, to control things this way.
Dynamo would be fine, but as long as it is not real-time, then it would never be the same thing.
