Anyone know a way to export to DGN with the short name from Revit and a new prefix? Renaming files afterward can kill sometime and I was hoping I could prevent that and have the export do it for me.
Thank you
Solved by Jason_S. Go to Solution.
Just get a free file manager/renaming tool. You can rename thousand of files using rules you define in seconds.
Below is an example I use:
I know I can rename them. But you lose all the references when renamed. I am trying to avoid losing those. Thought having it rename as it exported would keep the references and rename all in one. Looks like I have to open Mircostation and repath all the files.
