Hi!
I have a problem making a flat roof for a building with curved walls.
I use the roof by footprint modeling creation tool and make the footprint by picking all the walls and then set the slope to 0 degrees. When I click finish edit mode i get the message "Can't make footprint roof."
If a put a degree of > 0, it works fine.
What am i doing wrong, any help?
Best regards,
Kristian
Solved by planner_matlabi. Go to Solution.
Solved by ToanDN. Go to Solution.
Hi
Select Roof by Footprint
in option bar
unmark Define Slop
Before Sketch Draw
If it solves your problem, feel free to click Accept Solution.
