Export Sheets to DWG in the correct format
amy.cimerman
amy.cimerman
Hello Community,
I have a package I created to export, with my layers settings. When I export the Sheets with my own Legends as DWG, I open Autocad and I have my model correctly but I have the Legends not in the correct layer format.
For example,  I want to export A4 Horizontal, and the layout it appears in a A3 vertical, half of it is the correct layout, and half of it is empty.
What I'm I doing wrong when Exporting? The sheets in Revit have the correct measurement. I made a sheet for each type horizontal and vertical, but this is somehow not correctly transferred to Autocad.
Any advice would be really a lot of help to me.
Amy
RobDraw
It sounds like a lot of problems; a layer problem, a sheet size and orientation problem, and measurement problem.
I think you are going to have to provide a model with your export settings to sort everything out.
Rob
