Export to PDF Dialog Box
davidtetro
davidtetro
Is there a way of removing the 'Do You Want To Save Your Settings..." pop up from showing every time I go to export to PDF? It may not seem like much, but it is yet another thing to click in the seemingly over-amount of clicking needed to export to PDF.
Save your settings so that the next time you can just use them without lots of clicking and the dialog.
davidtetro
That doesn't work as there are different settings for each project.
Save different settings with different names.
davidtetro
Thank you for this option. But it is not answering my question. It is actually making more work. I want to know if there is a setting that will prevent that pop up from showing up.
You do more work upfront, once for each setting then you will never have to repeat them again.
Some options for dialogs are in Revit.ini file.  See if you can find it one for this.
