Export OBJ with correct geolocation
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm new to Revit, so apologies if it's something obvious but I've looked everywhere and still need help with the last bit of my puzzle.
I'm trying to export a 3D model as an OBJ, with the correct geolocation. My survey point is correct, angle to true north of the project base is correct, I'm sure this is just an export issue? I can't find any way to 'export to shared coordinates' as you can with DXF/DWG/IFC export options. I've tried the built in OBJ exporter, and an add on exporter with the same results, it always seems to come out on project base coordinates
Any help is gratefully received
