I Learned that PBR usually classifies two workflows:
1. The Metal-Roughness workflow usually includes Base Color, Metallic, Roughenss.
2. The Spacular-Glossiness workflow includes Difuse, Specular Reflection, Glossiness.
I need to convert the rvt file to gltf 2.0 file. This is the probled I encountered when processing the PBR material information.
I found that in Revit, the new PBR materials without exclamation mart use Image, Reflectance, and Roughness.
Gltf 2.0 uses Metal-Roughness workflow, including Base Color, Metallic, and Roughness.
This confused me, so I want to know what kind of workflow Revit uses, so as to help me correctly convert the Image, Reflectance, Roughness in Revit to the PBR material of gltf 2.0
Can I directly transfer
Revit Imange to gltf Base Color,
Revit Roughness to gltf Roughness,
Revit Reflectance to gltf KHR_materials_specular?
Or is there a better solution?
