Select the elements being monitored or select all elements in the 3D view, you can see the stop monitor icon in context menu.
there are tons of videos and blogs to learn this tool. knowledge.autodesk.com and www.youtube.com
Hope you found these links helpful.
It's a better tool if you use it effectively.
Thank You! and please 'Accept As Solution' when you found a solution, to help others.
