Export image crops outer pixels
Iev60047
Iev60047
This issue has been documented on the Revit API forums, but I was recommended by @jeremy_tammik to post about it here. Essentially, when I try to export an image from Revit, the resultant file has the outermost pixels cut off on one or two sides. I have uploaded two images, one is where the line weight is set to 3, and the other is where the line weight is set to 1. How do I report this issue to be fixed by Revit?
EATREVITPOOPCAD
Upload Revit file
The definition of insanity is doing the same thing over and over again and expecting different results
Iev60047
Done. I am attaching a different family than I originally used for this problem, but this happens to every kind of element. Scale is 1 1/12" = 1'-0". Crop view is turned off. In the next reply I am attaching the three picture with different line weight settings.
Edit: Revit family I attached does not save the visbility/graphic overrides that I applied. What I did to hide the reference planes/lines and unnecessary air direction arrows was to select all those elements and type "HC" (i.e. hide category). You could also approach this from the opposite method and select the air terminal and isolate that element.
Iev60047
Here are the three pictures. The first has annotation line weight of 0, the second has annotation line weight of 3 and the third has annotation line weight of 5.
L.Maas
Please do not cross-post to different forums.
Other thread is HERE.
Louis
Please mention Revit version, especially when uploading Revit files.
EATREVITPOOPCAD
@Iev60047 I think its because you have Current Window selected on export settings instead of Selected View
In the view you can also show the crop region and crop view as you want at the bottom
Iev60047
@L.Maas got it. I apologize. I'll continue communication on that end.
