Trouble extending curtain walls across an existing wall
martinezgabriella
Message 1 of 18
martinezgabriella
I am trying to extend a curtain wall across the top of an existing wall, but it just isn't working. The curtain wall ends up cutting into the existing wall, and the square bits (mullions?) become a jumbled mess. Can anyone help?
Replies (17)
Message 2 of 18
I don't see any "jumbled mess".
...if you have two walls occupying the same space, then remove one.
About Embedding Walls:
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Revit-M....
Message 3 of 18
hmunsell
is it going to be built like that? Is the glass going to be breaking thru the Parapet wall or is the parapet wall going to be solid and the window wrapping around it?
consider how your drawing your content, you may need to place 2 separate curtain walls, one on either side of the solid wall, or modify the solid wall to accommodate the cut out for the curtain wall.
Howard Munsell
Message 4 of 18
Maybe you are trying to solve for the corner return?
You would replace the border mullion at the corner with a L-Corner Mullion - and delete the Mullion on the joining Wall.
Message 5 of 18
Disallow join.
Message 6 of 18
martinezgabriella
 To be more specific, I am trying to do what is shown here. The curtain wall extends across the top of the wall, without cutting into it. It closes the gap (shown below) between one end of the curtain wall and the other end.
Message 7 of 18
Message 8 of 18
martinezgabriella
I can achieve a similar result, with the mullions not becoming weird, but then the curtain wall extends below the current wall.
Message 9 of 18
Why don't you model them as 3 separate curtain walls?
Message 10 of 18
martinezgabriella
They are all separate, none are joined to each other
Message 11 of 18
martinezgabriella
Yeah, I did that already so that they may attach to the roof. However, it didn't extend them.
Message 12 of 18
Actually, I still don't get it.  Really sounds like you are describing what I addressed before. That is, the type of Mullion used at the corner return.  L-Corner.
Message 13 of 18
martinezgabriella
It won't allow me to place those, and even if it did, wouldn't the curtain wall still extend below the existing wall?
Message 14 of 18
You need to share the file here.
Message 15 of 18
martinezgabriella
 So I put in the corner mullions, which solved my mullion problem, but the curtain wall still extends below the existing wall. I tried attaching the base to the wall, but that disconnects my roof attachment.
Message 16 of 18
Don't attach the base of the curtain wall to the parapet wall. Edit the curtain wall profile instead.
Message 17 of 18
martinezgabriella
Ok, thanks for your help. Turns out, I was the problem. For some reason, I was using the trim and extend tool as the align tool, which resulted in nothing working. Just aligned it, and everything was good.
Message 18 of 18
martinezgabriella
Oh yeah, and thanks for letting me know about the mullions. Looks a lot cleaner with a proper corner one.
https://www.youtube.com/watch?v=FjcXaIyFWq0
The video, if anyone is also struggling with mullions.
