How do you Miter two roof together?
3 ANTWORTEN 3
Nachricht 1 von 4
daleWLK5W
176 Aufrufe, 3 Antworten
Anyone know how I can miter the two roof together below?
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: daleWLK5W
Miter how?  Are you wanting the top and bottom planes of both roofs to be contiguous?  If so, redo both Roofs as one roof.  Alternatively, you could change the thickness of the low pitch roof so that it's bottom plane is contiguous with the bottom plane of the higher pitched roof.  But, you would need to get rid of the two-cut Plumb cut.
Or, you could leave them just the way they are and cover it with a Fascia.  Mitered of course.
Nachricht 3 von 4
...or you could cut the two Roofs with an In-Place Modeled Void.  Know how?
Nachricht 4 von 4
Have you used Roof by Extrusion method?  Use can use that method to create a two-pitch monolithic.
....BTW, a continuous fascia - mitered at that pitch change- might be all you need.   :zwinkerndes_Gesicht:
