Export identity data of links to IFC
ValkovicMario1
ValkovicMario1
I have multiple instances of one link at different positions in a project and every instance has unique name in Name parameter. Is there a way that this Name parameter will show up in separate IFCs of links when I do IFC export of main project? (Export linked files as separate IFCs - enabled)
ValkovicMario1
Missing linked models are not a problem here. I have separate exported IFCs of host model and linked models. This part works great. Problem is parameter Name (on the picture) won't show up in IFC of a linked model when opened in some IFC viewer.
From what I've read I think this might be something with making a new property set but there is no RVT Links category in IFC export classes. So I'm not sure if it's even possible.
