EXPORT DWG VIEW TRUE COLOR? PROBLEM IN AUTOCAD (EVERY LAYER IS BLACK)
07:54 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi Guyz,
I've got a little problem with DWG_Exportation: from Revit i Export to DWG 2010 and open the file on Autocad. In Exp_Settings I set at colors schedule True RGB colors because on revit I used a View Template with different colors ( cyan, red, grey...) but when I opend the DWG File into Autocad every layer is Black and Colors of printing too (in particular the solid fill hatches ). So wich is the parameter that I have to change in Revit o in Autocad to have the same colors used on Revit Project?
Thanks for any help.
