Export a DWG from Revit with different layers and color based on System Family types
manickavasakam_selvam
Hi every one ,
I have a issue with exporting DWG from Revit.
I follow method from the image below to export the DWG from Revit for export different wall type to different layers, its worked, but I want different colors also for different wall layers created. Is there any procedure to obtain that?
Any suggestion is welcomed.
Thank you in advance
dsidelVAAQZ
I don't have a complete answer, but maybe a partial answer...
When in the Modify DWG/DXF Export Setup, looking at the Layers tab and the Walls Category, one can Add/Edit a Layer modifier for Projection or Cut. I think this is the way towards a solution and here is a further explanation of using modifiers:
https://forums.autodesk.com/t5/community-blog/using-layer-modifiers-for-a-more-accurate-dwg-export-i...
Like I said, not a complete answer, but I hope it helps you on the path.
Thank you for your response and link you provide also is useful.
Actually, there is the way I am using Fire rating to export in different layers. I don't know there is separate layers and colors for fire rating in layer settings, its worked when change the color in the fire rating layer like image showed. below
