PDF Exported Color Scheme Hatch Pattern covered Wall Cutlines and Door Swinging Track
1 ANTWORT 1
Nachricht 1 von 2
NguyenTriTrung
96 Aufrufe, 1 Antwort
I want to display Room's color scheme by hatching pattern instead of using solid color.
However, the hatch pattern doesn't seem right after exporting into PDF. The Pattern covered Wall Cutlines and Door Swinging Track unlike showing on Revit. Please see attached photo.
I have to overlay another view which shows only wall and door for this but it's not a good method I think.
Do you have any idea for this?
1 ANTWORT 1
Nachricht 2 von 2
nozci
als Antwort auf: NguyenTriTrung
It is correct in Revit view but not correct in PDF export right. It happened to me, too.
Looks like a bug in PDF export. I think Revit calculates the view and do it correctly. But PDF export uses the entering sequence of the members.
Cut your wall and paste again. Or delete your wall and draw again. The wall should be entered last not to be overridden during PDF export. It had worked for me.
