We are thrilled to share the big news – Autodesk Informed Design is now officially here, and we couldn't be more excited to introduce it to our amazing community!
Autodesk Informed Design is a comprehensive product solution that integrates both Autodesk Inventor and Autodesk Revit through a cloud-based web application. This setup provides a more streamlined workflow for product manufacturers and designers, enhancing efficiency in the building design and construction process. Informed Design permits designers to design with customizable, pre-defined building products, ensuring manufacturable results. It also facilitates manufacturers in sharing their products with design stakeholders. By applying manufacturing principles to the built environment, Informed Design paves the way for industrialized construction, heralding a transformation in the architecture, engineering, construction, and operations (AECO) industry
Informed Design for Autodesk Inventor enables product managers and product engineers to align their manufacturing capabilities with customer requirements. This add-in for Inventor 2024 provides a more streamlined design and manufacturing process.
Capabilities include:
Informed Design for Autodesk Revit allows design professionals to design with known-manufacturable building products for unparalleled certainty and quality. This add-in for Revit 2024 provides improved design quality, increases workload capacities and reduces errors and rework.
Informed Design Web Application allows product manufacturers to capture all the as-designed information directly from design professional’s models. To then generate output all manufacturable product information such as bill of materials (BoM), drawings, and model outputs. This web-based application speeds up the process from design to manufacture, reduces errors and rework.
Product release status: Product manufactures can control their product release status when new releases as shared and old ones are obsolete.
Get Connected!
- Introduce yourself and join the conversation on the Community Forum
- Join the "Connect Design and Make with Autodesk Informed Design" webinar, hosted in partnership with Engineering News-Radio (ENR) on February 20, 2024. For more information and to register, visit ENR’s website.
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Looks very interesting. Is this Add-in already available in the Autodesk account? For what versions of Revit?
Hi @Alfredo_Medina,
If you head over to the Autodesk Informed Design community pages here. We have put together lots of information for you to get started.
Please note users will require licenses of Inventor and/or Revit respectively to use it.
@Alfredo_Medina yes this is out now currently it works with only revit & inventor 2024
DarrenP
Thanks!
I have the latest Revit version but still cannot install or use Informed Design for Revit. I have revit 2024.2 open in the background and checked Autodesk Access for updates but on the same screen Informed Design Installer states Revit 2024 is required.
Can you take a look at the issue @umut.akparlar is experiencing?
Jonathan Hand
Thanks @handjonathan,
@umut.akparlar has posted the problem on our community forum. Where the answer has been resolved. 👌
It could be related to an issue some users reported with the Revit 2024.2 update. Can you take a look at the following article and see if the steps in this article help resolve the issue? https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Revit-2024-2-Updat...
