Exact size for tiles in model. Is it possible?
nsec-user1
nsec-user1
Hi, may I ask if it is possible to create an exact size of tiles in Revit using materials? Or do I have to do it manually? Thank you. Kindly find attached image for reference.
zeulrick
Yes, you would create a floor with a custom material with the tile option selected. Then change the tile pattern layout. Then change the scale to the dimension of your desired tile sizes. You can then also modify the grout size. You then change the color of the tile to a color or image file. Hope this helps!
zeulrick
I just looked at the image you provided of the tile patterns you need to create. Those are going to be tricky. My method won't work. You might have to model each tile manually. Ugh. Someone else might know a better way
nsec-user1
this would help too...thanks
