CAD to Revit, Site Lines not showing, title block is
Normally I make everything in CAD 1 layer, run explode, run purge, and save down to 2007. I use ACAD 2020 and Revit 2020. Only the title block is showing on my import, not the site lines. Attaching the CAD file.
Attaching the CAD file. Thank you.
zeulrick
When I dropped your dwg. into my model, everything showed up fine. Try checking your (vv) visibility graphics overrides. and go to imported categories and select all the layers in your dwg. file that you want to be visible.
This is not solving the issue on my end. I made all the site lines layer 0, which is selected as visible. Links are also selected as visible. attaching a screenshot.
zeulrick
You need to link the cad drawing to a view in the project then place that view on your sheet where the title block is.
