ESCAPE Key not working (REVIT 2023)
5 REPLIES 5
jjacarabbacan2019
704 Views, 5 Replies
Escape key does not work and I literally had to right click and cancel when placing components. I tried restarting and the problem still persists. My keyboard is okay so that had to be ruled out.
5 REPLIES 5
Hi!
Still the problem?
In my case with the hotfix I've no longer that problem
Gustavo Ubriaco Contreras
I am having the same issue, along with the delete key doing the same thing. On the system keyboard and wireless keyboard. It is a big pain!
Hi, I have the same problem, do you have a workaround for this guys?. it's been ages and this problem still persist. i dont know what autodesk did until 2024 version of revit.
Does the Autodesk Knowledge Base on this topic offer and solutions you have not tried?
ESC key or other shortcuts stop working in Revit (autodesk.com)
Jay Colcombe
Autodesk Certified Instructor
Hi Jay, I already tried all of them. Restarting my computer is the only solution that has ever worked for me for each version of revit we are using. (Revit 2021, 2023 and 2024)
All of those version appears to be affected by this problem.
All of these functions does not work altogether.
ESC
Delete
CTRL+C
CTRL+V
CTRL+X
I dont know if someone encountered more functions that has been disabled. But for me, restarting my computer is the only way but I dont do these often as opening my model takes alot of time and effort.
Forma Design Contest
