ESC key will not work in Revit but works everywhere else
100 REPLIES 100
Message 1 of 101
56654 Views, 100 Replies
So we are having a problem with revit where the esc key does not work but it works everywhere else.  It is not an adobe product as we do not use those programs.  Any ideas?
100 REPLIES 100
Message 61 of 101
didn't work
Message 62 of 101
jb.reinert
in reply to: jb.reinert
Since the only option for me is to close and restart just to have this issue occur minutes or at best hours after restarting, I've added a shortcut key for MD, directly under the escape key for when this occurs (`). The tilde/grave accent key is now equal to the escape key. It's hard to believe Autodesk hasn't found a solution to this, but hopefully this is helpful to others experiencing the same issue. To add a shortcut key, go to the File drop down, select Options, User Interface tab, Keyboard Shortcuts: Customize. From there find and select Modify (MD), type the grave accent key(`) and then click Assign to assign the new shortcut.
Message 63 of 101
RSomppi
Please see message #60.
Message 64 of 101
RobDraw
How do you expect them to find a solution if it cannot be recreated? It's very difficult, if not impossible, to trouble shoot random.
Rob
Message 65 of 101
drosenthalUQMVQ
in reply to: RobDraw
reported you - get off the thread if you don't have a helpful response
Message 66 of 101
RobDraw
in reply to: drosenthalUQMVQ
Hello?! Is your thread helpful?
What did you report me for? Did I offend you?
Rob
Message 67 of 101
What about the delete key?
Message 68 of 101
sdurkee_sa
Here is what we have found on our computers. This won't apply to everyone, but hope this helps someone at Autodesk track this down. We will also send this info to Enscape. See the link in message 60 for an explanation of some of these tests.
Issue:
  1. Open Project 1 and run Enscape.
  2. Open Project 2 and edit a family.
  3. Select "Load into Project and Close" and select Project 1 to load it into.
  4. [Esc] key stops working.
  5. [Delete] key stops working ([Tab] key still works for us).
  6. Properties palette stops updating when items are selected. Selecting the Properties dialog updates the Properties palette.
  7. Filter in the lower right-hand corner doesn’t update number of items and won’t open but the Filter command in the Ribbon works.
Checked:
  • Keyboard driver is up-to-date.
  • Video Card driver is one month old.
  • Revit 2022 is up-to-date.
  • Keyboard shortcut “MD” does cancel the selection but does not enable the [Esc] key.
  • [Alt+Esc] switches between windows or programs in the order that they were opened and has no effect on this issue (not sure why this was in the list).
  • “Right-click | Cancel” does cancel the selection but does not enable the [Esc] key.
  • “[Alt] | A | MO” has no effect (also don't know why this was in the list).
  • Opening “File | Options” dialog has no effect.
  • This project was just opened, there is no text that was last edited to select.
  • Starting a new project had no effect.
  • Saving or syncing had no effect.
  • Closing other open apps (Chrome, Outlook, Adobe Acrobat, Photos, Windows Explorer) had no effect.
  • Closed Revit and reopen to get [Esc] to work again.
Message 69 of 101
sdurkee_sa
in reply to: sdurkee_sa
Did more testing of different scenarios. Nothing we tried maintains or restores normal functionality of [Esc], [Delete], Properties, and Filter other than restarting Revit.
One change to the process that seems to avoid the issue is to select "Load into Project" instead of "Load into Project and Close".
Old joke:
Patient: "Doctor, it hurts if I do this."
Doctor: "Don't do that."
Message 70 of 101
JL.FCG
I have come across this issue in the past, and have found that 9 times out of 10 there is a pop up somewhere.
Usually a Revit Add-in.
However, there have been Windows pop-ups that have also interfered with my Revit - so i would open task manager and close all programmes apart from Revit to see if it makes a difference, because in my case - it takes a lot longer to open a Revit Model than it would Outlook, or Windows Folders.
Message 71 of 101
ian.withersMKBGW
I too have this issue.  Its only just started but it'll start doing it about an hour into my revit session...every friggin day, 10 times a day.  It takes 20mins or more to open my model, so a re-boot is out of the question.  ALL shortcut commands and the escape key and delete keys just stop working.  I have to right-click and select delete, or select the modify command from the ribbon.  This is infuriating.  I am running 2021.1.5.  My laptop keyboard and my steelseries are both having the same issue, so its not the drivers.
Message 72 of 101
ian.withersMKBGW
Sorry, update its happening on my revit 2023 version as well... I run both 2021 and 2023 for different projects.
Message 73 of 101
I get the issue even when not editing families.
Message 74 of 101
RobDraw
It seems this problem is impossible to troubleshoot any further. The causes are many and so are the solutions.
Rob
Message 75 of 101
@ian.withersMKBGW, I also run revit 2022 and 2023 for different projects and the problem is consistent and has been for a year despite updates etc....it is extremely frustrating, but if you follow the directions below to add 'an additional escape key' as a shortcut key it will lessen your frustration immensely. (You can see this in message 13 above).
"Since the only option for me is to close and restart just to have this issue occur minutes or at best hours after restarting, I've added a shortcut key for MD, directly under the escape key for when this occurs (`). The tilde/grave accent key is now equal to the escape key. It's hard to believe Autodesk hasn't found a solution to this, but hopefully this is helpful to others experiencing the same issue. To add a shortcut key, go to the File drop down, select Options, User Interface tab, Keyboard Shortcuts: Customize. From there find and select Modify (MD), type the grave accent key(`) and then click Assign to assign the new shortcut."
Message 76 of 101
Lance.Coffey
@jb.reinert thank you for the tip about using a keyboard shortcut as an alternative to the Esc key. I've added this to the article along with @sdurkee_sa's info that when editing families (while Enscape is loaded) using the Load into Family option instead of Load into Family and Close helped prevent the issue from showing up.
It sounds like the issue @ian.withersMKBGW is seeing is different from prior reports, as all shortcut commands are affected. Ian, can you confirm that all Keyboard Shortcuts are affected when this is happening and have you gone through the steps from the article linked above?
Lance Coffey
Technical Support Specialist
Message 77 of 101
Yes, I can confirm that all shortcuts stop working including MD.
I am then forced to use only the buttons on the ribbon or right click to pull up some more options. This happens in both 2023.1 and 2021.
I have tried all of the above proposed solutions. Obviously restarting works...for a bit, but I am using some pretty large models on ACC so restarting takes significant amounts of time.
Message 78 of 101
RobDraw
That sounds like you are losing the connection to the shortcuts file.
Rob
Message 79 of 101
On the prior troubleshooting:
  • Can you confirm that a system restart is required to clear the behavior (not just restarting Revit)?
    • If restarting Revit clears issue, did you see any change in frequency when disabling add-ons?
    • If restarting the system is required to clear the issue, did you see any change in frequency when putting Windows into a simplified startup environment?
Regarding the connection to the Keyboard Shortcuts file that @RobDraw mentioned, have you tested exporting/importing your shortcuts when this is happening (also if your shortcuts file is stored on a network/cloud location, try copying it locally)?
Lance Coffey
Message 80 of 101
sdurkee_sa
Three different coworkers reported the issue with [Esc] and [Delete] keys not working in Revit 2022 today. None of these were related to the Family editing issue. The only workaround that brought [Esc] and [Delete] back in Revit was closing and reopening Revit.
