ERROR
ERROR
ERROR
While i working in revit 2015 some edit options is not working ,for this issue  i restart the software ,after that while i open my file it showing like
"Data in file (filename).rvt is corrupt and needs to be manually recovered".
i followed the instructions whatever you mentioned in the site for resolving this issue, but my problem is not fixed.
ennujozlagam
hi, have  you try to re-install the software, maybe some program files are corrupted.thanks
Yes ,my problem was fixed. I reinstall the software and used audit option.
ennujozlagam
hi, thats great...please close the issue and mark as a solution and if happy give kudos. thanks
