Error when I load a profile family to revit model.
ali_sheikhK66QK
Message 1 of 15
ali_sheikhK66QK
I have been getting the following error when I try to load my custom made profile family into the REVIT. I have attached the following screen shot. The lines on my profile is very short.
If some one can help me that would be really appreciated.
Replies (14)
Message 2 of 15
You probably have one or more overlapping lines in the Profile Family.
Message 3 of 15
Tom_Kunsman
Can you post the profile? it seems like there is some error, likely the profile is not a closed loop
Message 4 of 15
ali_sheikhK66QK
When I increase the scale of the profile it gets loaded. Thats strange.
Message 5 of 15
Tom_Kunsman
Possibile it might be too small. Please post it so we can help better
Message 6 of 15
ali_sheikhK66QK
The profile is follows.
Message 7 of 15
Tom_Kunsman
not seeing it . . .
Message 8 of 15
ali_sheikhK66QK
Can you see now?
Message 9 of 15
If your intention is to create geometry from this profile, that's a ridiculous amount of detail that won't even be legible once Thin Lines is turned OFF.  Also, minimum line length in Revit is 1/32".
....I'm specifically referring to the teeny tiny fillets and grooves.
Message 10 of 15
Tom_Kunsman
@ali_sheikhK66QK  I agree with @barthbradley  - and you only posted the JPG not the RFA file -
Message 11 of 15
ali_sheikhK66QK
I have attached the RVT file for my profile. But there should be a way of incorporating such tiny details.
Message 12 of 15
Message 13 of 15
ali_sheikhK66QK
Okay, thanks for all the help.
Message 14 of 15
There is. With 2D Detail Families. That's not your issue here.  Your issue is that you are trying to create 3D geometry from this 2D Profile Family.
Message 15 of 15
Open the attached Family and see how I modeled the sweep geometry using a simplified version of your Profile Family (named Angle Profile.rfa) and how the Left/Right Side Elevations displays a very different profile that looks like your original profile with teeny tiny fillets and grooves.  That is 2D display coming from a nested Detail Family named Angle Detail.rfa. That Detail is the only thing visible in Left/Right Elevations.  The sweep geometry is hidden in the Left/Right Elevation Views via its Visibility Settings.
