Error when exporting NWC from Revit
joker9757
joker9757
Hello, all.
I am currently using the Navisworks Exporter in the add-ins tab.
The main problem is that I come across the error message looks like below every time, and I do not know why it appears and bothers me consistently. I went through other threads, and it told me to change the print settings and paper settings. However, it doesn`t work at all.
Is there any method for resolving this issue?
Below images are the error message and my print setting.
Thanks for your consideration,
Can you change the Windows default printer to a different one other than Microsoft Print to PDF?
joker9757
Hi ToadDN
I finally solved this problem. I do not know it is the actual solution for this, but it was due to the print setting in linked files. I opened the every linked file and delete all page settings, and it works.
Thanks for your consideration.
Has anyone made any more headway on this?
This issue is still not solved by Autodesk https://knowledge.autodesk.com/support/navisworks-products/troubleshooting/caas/sfdcarticles/sfdcart...
but, changing the windows default printer or the linked file print settings seems to bypass the issue.
ydju01
I agree. It seems that the change of printer setting is not a perfect solution.
I thought that I wouldn`t see the same error message after the change of printer setting, but it has popped up from time to time.
