Hi Forum,
I have an issu with exporting the slab edges to the IfcFooting Class.
We use the slab edges on our structural Foundations since it is really fast to model & change, compared to an inplace family.
According the IDM ( Information delivery manual) of the project we need to include several custom parameter into the IFC. To do this i use the "Export user defined property sets" Option which reads an input file. ( If you are not familiar with this method, feel free to ask, i will provide more detail explanation)
This export needs however that the Slab edge instances are in the correct IFC- class before a custom property set can be attached.
For our deliverable this means:
Does anybody know what is missing, or why i am not able to export the slab edges into IfcFooting.
Thanks in advance
*Note: this plattform does not accept the upload if an *.ifc file. So i just zipped it. To open simply unzip.
Allthough we are using a german Version we have the exact same problem. We cannot export slab edges to IfcFooting. Did you find a solution yet?
best regards, Christoph
