Error Render Cloud
3 REPLIES 3
Diogo_Nery
490 Views, 3 Replies
Error Render Cloud
Since January, I have been trying to use the rendered cloud and I have not succeeded, always with the same error! The Brazilian forums cannot solve it, I came to the American forum!
OBS: INTERNET: 15 MEGA.
ANTIVIRUS ON AND OFF.
I TESTED MORE COMPUTERS.
THE ERROR PERSISTS WITH THE SAME LOGIN OF THE 360 AND THIRD-PARTY ALSO
ALREADY DISINSTALLED THE REVIT AND REINSTALLED, SO AS I DISCRIMINATED THE AUTODESK DIRECTORY, IT ALREADY FAILED TO FORMAT THE COMPUTER, BUT THE ERROR STILL PERSISTS! SOMEONE HAS A SOLUTION.
Diogo H. Nery
3 REPLIES 3
Diogo_Nery
in reply to: Diogo_Nery
this was the last project rendered in the cloud! I took the test with him again and the error continued!
Diogo H. Nery
Viveka_CD
Hi @Diogo_Nery
Please remove the () brackets from your file name and re-name it.
Isolate conflicting add-ins by disabling them (see How to disable add-ins for Revit).
Please install your Revit with the latest updates.
Let me know if you have any questions and if this helps with your issue.
See article: https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Diogo_Nery
in reply to: Viveka_CD
Hello Viveka, neither option influences anything, I've done renders without taking the brackets! however, it was decided to install the latest Revit! Thanks
Diogo H. Nery
