Error message when importing dwg file
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all,
I'm trying to import a dwg file (a purchased area map) into revit LT 25 but getting the attached error message.
This is something I have done hundreds of times with no issue.
I can import other similar dwgs into the same project with no issue at all. No other problems with this particular project file.
I have created a new project, tried importing this same file but get the same error.
I've tried importing the offending dwg into other project files and get the same error.
The dwg file seems to open fine in the online autodesk dwg viewer (I do not have autocad installed).
Any thoughts gratefully received.
