Filled Region Issue
1 ANTWORT 1
Nachricht 1 von 2
STaylorDEEGK
128 Aufrufe, 1 Antwort
Filled Region Issue
I am having an issue using filled regions. The filled regions I have already drawn are unable to be copied, and any region I try to draw from scratch just turns into lines once I accept the boundary, like I just drew the shape with detail lines.
I am also having this issue with model elements that use a bounday - floors, ceilings, etc. - they just turn into magenta boundary lines instead of the floor, ceiling, used.
1 ANTWORT 1
Nachricht 2 von 2
TripleM-Dev.net
als Antwort auf: STaylorDEEGK
Have you re-started revit, and is it still happening?
I had something similar, a Addin was causing this under Windows 11 (under Win 10, it didn't do that with same Revit + update + addin version) It also cause the UIView panels to pop-out and soon after the model would crash.
It seems like Revit was handling a single click as double click, but internally revit didn't follow that so it became unstable. After uninstalling that addin I never experienced it again. Not necessarily the addin fault but combi Addin + Win 11 + maybe some win drivers for mouse (tried others)
