I have a problem with the export files to DWG in Revit 2019.
First DWG exportation is ok, then Revit save a 0 kB dwg files. This happens with any sheet of any discipline/systems.
Sometimes this message appears.
The following views could not be published.
Anyway, only after closing the program and opening it again that I can continue exporting.
Does anyone know if it's a known problem?
Solved by lucdoucet_msdl. Go to Solution.
Here is a Revit Help page on that particular subject:
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Hope this resolves your problem.
-luc
