Error Dialog box Missing
eddyp
Message 1 of 17
eddyp
I have narrowed down my problem to my ERROR DIALOG box is missing on REVIT 2020.1.
I've tried all the tricks to relocate it if it happens to be off screen but none have been successful.
alt+space Move, alt+TAB, Resize screen resolution, isolate to single screen , ...
I'm open to other suggestions but the problem started 2 days ago, I believe after Revit update.  My secondary laptop did same update but not having any issues.
I've tried REVIT: repair, reinstall, uninstall/reinstalll... no change
Any ideas?
Accepted solutions (4)
Replies (16)
Message 2 of 17
Multiple monitors setup at one time? Set it up again and see if error box is on it.
Message 3 of 17
RobDraw
Several other people have posted the same problem. I have not seen a solution, yet. Keep your eye on those other posts.
Rob
Message 4 of 17
Disappointing.  Sounds like a 2020.1 Update Hot Fix may be needed.  Maybe we'll just wait to apply this "High Severity" update.  Thanks for the heads up.
Message 5 of 17
eddyp
I have 3 monitors ...  Are you suggesting unplug 2 and try single screen only?
I just did a graphics card up date but no change their either.
Message 6 of 17
eddyp
I've searched high and low for same issue but not found anything yet.  Where are you seeing reports of similar problem?  so that I can keep tabs on possible solutions
Message 7 of 17
No, that is not what I was suggesting.  The opposite. If you had a multi setup and went to one monitor, then go back and check.  Clearly that's not applicable here since you currently have a multi setup.
Another thought: Add-ins.  Try troubleshooting by disabling Add-ins.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/sfdcarticles/sfdcarticles/H...
Message 8 of 17
Tony_Michniewicz
User feedback and testing indicates that this issue is related to the Revit InfraWorks Updater 2020.1 add-in.  An updated version that includes a fix for this problem should be available in the near future.  Until then, the only known solution is to uninstall the Revit InfraWorks Updater 2020.1 add-in.
Tony Michniewicz
Revit Software QA Analyst
Message 9 of 17
eddyp
Bingo that is it!!!  I disabled the Add-ins, per instructions and my dialog box reappeared. Now how do I figure out which Add-in was the problem? I add pic of temp folder I created that had 2020 Add-ins
"Another thought: Add-ins.  Try troubleshooting by disabling Add-ins. "
Message 10 of 17
Well, it's a process of elimination now - unfortunately.  One or more of those boogers is the culprit - most like a third-party Add-In.  Start uninstalling/reinstalling one-by-one.
Message 11 of 17
Ah! Just saw @Tony_Michniewicz  post. There you go! Hopefully.  Good Luck!
Message 12 of 17
RobDraw
I think you've got the information you need, correct?
Rob
Message 13 of 17
Message 14 of 17
Think I could get one of those lil' green check marks?
Message 15 of 17
eddyp
I uninstalled "AutoDesk InfraWorks" from Win10 Apps & Features.  So far so good
Message 16 of 17
AAAStructural
I have 3 monitors and windows 10 professional  I occassionally find "orange" parts of my model while performing a task.  I can't find the dialog box.  Everything in the program is grayed out.  I first try the alt-spacebar-M-arrow key combination of windows to move the revit window.  If that doesn't work, I turn off each monitor, one at a time.  The dialog box can appear suddenly on one of the "still-on" two monitors.  I can then click on the warning "ok" and resume.  Oh, yes, I turn back on the third monitor.
Message 17 of 17
anielson
I just had this problem in Revit 2021 in Windows 11.
I opened my display settings and changed my monitor scale. On one monitor, changing it to like 200% made the dialogue box show up. On a different monitor, changing it from 125% to 100% made the dialogue box appear. If that helps anyone.
