when i try two different profile on on zigzag line by sweep blend command its not work shows me some error.
Solved by barthbradley. Go to Solution.
Thanks a lot for posting your question to the forums! Has the solution suggested by @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community!
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
