Error 3050
Error 3050
bim2.ntec
Message 1 of 8
Error 3050
bim2.ntec
Error massage 3050 interrupted when I clicked update Issues Addin v5.0.8 for Revit 2022. What going on? How to solve the problem?
Replies (7)
Message 2 of 8
FuldenYilmaz
One common cause of installation error 3050 is that you are trying to update a product that is not installed on your computer. Make sure you have the main version of the software before applying any updates. In addition, I suggest that you should control C File - Autodesk Installation Files updates can be required for the files.
Another possible cause is that something went wrong while preparing for installation. You may need to exit and start the install again using a different method
You can also check if your operating system meets the system requirements for the product you want to install
Let me know if you have more questions on this topic, otherwise please accept as a solution so that others can benefit from this information.
Message 3 of 8
phil_delaughter
We are having the same issue on most of our machines.  This is also happening with Issues v5.0.8 for Revit 2023.  Anyone have a fix?
Message 4 of 8
kmuir
This does not resolve the problem and therefore should not be marked as "solved".
Message 5 of 8
FuldenYilmaz
Hi @kmuir ;
As you know, answer acceptances are making the problem opener. It's not about me, actually, I just conveyed my advice
However, considering that you have the same problem, I would like to say that I did not have any problems when I downloaded this add-in through Autodesk Manage.
Message 6 of 8
phil_delaughter
For anyone else having this issue, Autodesk support was able to provide me a solution that worked for me.  You must install the latest version of Autodesk Installation Service (AdODIS-installer.exe) first before installing Issues 5.0.8.  You can download it from https://emsfs.autodesk.com/utility/odis/1/installer/latest/AdODIS-installer.exe.
Message 7 of 8
johan_van_mol
@phil_delaughter: thank you, this is the correct solution. This should be marked as "solved".
Message 8 of 8
M_mozaffari92
Community Visitor
Community Visitor
Thanks a lot
