Dimension and Grid Bubble Position on Different Sheets
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
dm0144
242 Aufrufe, 1 Antwort
I have two similar questions regarding placement of annotations in the exact position (or fixed offset from from the building) over different floor plans.
1. Is it possible to set the dimensions on the same exact position for different floor plans, so on level 1 are on the exact same position as level 2 (or to have fixed offset from building element such as wall if placed on different side)?
2. When the side of the grid bubbles changes over different levels, is it possible to set them on the exact offset from the building, so that the left and right grid bubbles have the same offset from the building?
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: dm0144
  1. Use Copy paste aligned.
  2. Use Propagate extent.
