One common cause of installation error 3050 is that you are trying to update a product that is not installed on your computer. Make sure you have the main version of the software before applying any updates. In addition, I suggest that you should control C File - Autodesk Installation Files updates can be required for the files.
Another possible cause is that something went wrong while preparing for installation. You may need to exit and start the install again using a different method
You can also check if your operating system meets the system requirements for the product you want to install
Let me know if you have more questions on this topic, otherwise please accept as a solution so that others can benefit from this information.
