Equation help for Revit family parameters
bbrumfield
Message 1 of 9
bbrumfield
Hi everyone, I am new to Revit and primarily work with inventor and have hit a road block with this parameter equation.
=TAN(15°*PI()/180°)*(Depth-1.500), Depth-1.5 = 11.5 in this case answer should be 3.081 the closest I've gotten throwing darts was = (Depth-1.500)*15°*pi()/180° which is returning 3.011
Any help would be greatly appreciated.
Brent F. Brumfield
Replies (8)
Message 2 of 9
What is Depth?
Message 3 of 9
bbrumfield
In this case actual depth is 13.500 inches - 1.500 inches = 11.500 inches. The Depth can change the 1.500 dimension and 15 degree angle are constant.
Message 4 of 9
Sorry I don't get it.  How can Depth varies and you expect the outcome to be a fixed value?  And 13.5-1.5 = 12 btw.
Message 5 of 9
bbrumfield
Sotshould have been 13
Message 6 of 9
TAN(15°*PI()/180°)
This doesn't make sense.  15d divided by 180d even out the unit.  It is no longer an angle to calculate TAN.
Message 7 of 9
bbrumfield
The posted equation works with imparts or model states in Inventor. 11.5 would be the base length, 15 degas the angle. However I solved the issue. Parameter B = Depth(any) - 1.500 inches. Parameter Rise = B * tan(15deg)
Message 8 of 9
The above formula makes sense. The original doesn't.  Why did you introduce pi()*180d is a mystery.
Message 9 of 9
TripleM-Dev.net
See link below, an old post from "RevitForum" with possible revit formula's which includes calculations with angles:
https://www.revitforum.org/node/1126
