Enscape will not open with Revit file
NAUMES
Message 1 of 10
NAUMES
I have been using Enscape with a Revit file for a few months now. A few days ago, Enscape stopped opening with this particular file and causes everything to crash. I have updated my drivers, updated enscape, tried copying the file, nothing works. Sometimes, Enscape will run upon first opening the file, but if I add any other elements to my model after opening it, Enscape will not work. I feel that it may be my Revit file; the first time this happened, something popped up saying my revit file was corrupt. I am not sure what to do.
Replies (9)
Message 2 of 10
syman2000
Upload the file and see if people run into the same issue
Message 3 of 10
Message 4 of 10
NAUMES
Here is my file.
Message 5 of 10
NAUMES
I just tried this and it did not work, unfortunately
Message 6 of 10
Is it possible that your Enscape license has expired?
Message 7 of 10
syman2000
I tried it and it seems to open the enscape fine from my end. Can you check if you have Revit 2020.2 and Enscape 2.9?
Message 8 of 10
Base12
With larger files and/or lots of materials being assigned, if I don't crop the 3D view Enscape will crash.  Also if the model is a long way from the origin point, cropping the view can fix the problem.
Message 9 of 10
Alfredo_Medina
In that case the problem many not be related to Enscape nor Revit. It could be simply that you don´t have enough space in your C drive for temporary files.
Message 10 of 10
syman2000
Also keep in mind using 4k or 8k texture will make enscape load longer and slower. Often this will lead to your enscape crashing. So keep the file to 2k or 1k for faster and more stable result.
