Enhancement for Path of Travel
2 REPLIES 2
tommy_yeung
667 Views, 2 Replies
Full-Auto Update Function
At this time, to update the path of travel, there are only few ways to make it happen including select the path of travel line and manually press ‘Update’ and change the start point/end point for path re-calculation. But, the practical situation is, design change is always producing the change of model elements rather than path of travel, we need a tool that it will follow the model change and auto-update the path when the model is keep changing.
Workability of Dimension
For the statutory submission, dimension is a functional tool to be used commonly to tag the length of travel distance and other information due to statutory requirement. At this moment, we can’t apply the angular dimension for path of travel to present the degree between two separated travel directions. I hope it will be solved in the future version of Revit.
Labels (1)
2 REPLIES 2
RDAOU
in reply to: tommy_yeung
@tommy_yeung
You should take your ideas and post them on Revit Ideas forum...HERE +----> https://forums.autodesk.com/t5/revit-ideas/idb-p/302
On this forum, best case scenario would be people suggesting workarounds
tommy_yeung
in reply to: RDAOU
Oh yes, I just post them on Revit Ideas forum
thank you so much
Forma Design Contest
