Enhanced Realistic View in 2021/2022 Setting back to 2020/2019 Version Setting
How do I set the realistic view in 2021/2022 version to 2020/2019 version so it is not enhanced with light and shadow. I only want to show the materials and color as consistent colors.2020202020222022
ennujozlagam
you can refer to these LINK and LINK and see if helps. thanks
Consistent Colors and Realistic are two completely different Visual Styles.  If you want to change the Realistic display, play with the settings under View's Graphic Display Options.  Other than that, learn to love the "Enhanced" look.  There's no going back.
Graphic Display Options | Revit Products 2022 | Autodesk Knowledge Network
