We are facing one issue for Baffle adaptive component placing in one curved surface (adaptive mass). Mainly we need the end cut of the baffle like attached snap. Suggestion/Solution will be much appreciated.
Attachment Snap:
Requirement.png -- is our Requirement
Elevation view from our model.png -- which we have generated
Attachment Snap:
Attach the family
Attach the family
Attaching the file for your ready reference & review.
In Both the nested Profile family and the Type 3 Points family:
Change the adaptive Component Orientation to Host XYZ
Thank you for your suggestion. Mainly want to see the end cut like below snap. Waiting for your valuable suggestion
I understood your question the first time...to have the component's normal follow the normal of the host. Change the orientation of the adaptive to XYZ Host (where Z is the normal) as mentioned in the previous reply. It is the purpose of an adaptive to adapt to certain conditions...in this case it is the curve hosting it
In the images I posted above, the cure ends tangent to the horizontal plane...
