Enabling scale to Perspective view -insert view into a sheet.
mzmaso90
Message 1 of 17
mzmaso90
I cannot find a way to scale a perspective view into a sheet. Would you help me to fit it into a specific space?
Best regards
Lorenzo
Replies (16)
Message 2 of 17
syman2000
When dealing with perspective view, you have to select the view and click on size crop. Here click on the scale (lock proportion) and change the size of the view so it fits in your sheet.
Message 3 of 17
Why don't you just toggle Projection Mode to Orthographic, change the View Scale and then toggle it back to Perspective?
Message 4 of 17
mzmaso90
Do you now how to go back? the perspective view is set to grey, and even the unlocked view doesn't let me change it.
Message 5 of 17
syman2000
Use view cube to toggle between the two
Message 6 of 17
mzmaso90
Thank you for your tip, but there both options are still grey:
Message 7 of 17
View Template?  Sounds like it.
Message 8 of 17
Try activating Crop View
Message 9 of 17
mzmaso90
No, I checked.
Message 10 of 17
mzmaso90
Neither
Message 11 of 17
mzmaso90
No view template applied, I click on active crop view but neither here, I can switch grey to modifiable settingmzmaso90_0-1698596701252.png
Message 12 of 17
check "ritaglia vista"
Message 13 of 17
mzmaso90
Is in grey as well
Message 14 of 17
Is the View placed on a Sheet?
Message 15 of 17
mzmaso90
YES
Message 16 of 17
Remove it from sheet.
Message 17 of 17
syman2000
Try turning on the crop view. Select the crop view and click on size crop at the top of the ribbon tab like the first post I posted.
