Elevation View and 3D View Problem (elements Not shown when placed outside the North/East/South./West Problem )
ahmadkhalaf7892
ahmadkhalaf7892
Hello Currently I am placing Generic models which are supposed to be a tunnel in Revit . The thing is I am placing them outside the North/east/South/west/  Elevation View . Then I am moving the Elevations (North east …) to  see my tunnel in the plan view .
My problem is that I cannot locate them in 3D model they are not directly visible , and in the north view I cannot see the levels assigned or near the generic elements .
How can I fix this issue . I know I can move the generic models into the Views but I don't want this approach since I might need the points and their location.
what is the best approach for such an issue .
Replies (11)
Post the actual RVT file and we'll take a look at it and advise you.
...also, here's a handy reference to check when you can't find "stuff" in the View:
Missing Something in a Revit View? 33 Steps to Find Stuff | Ideate Inc
ahmadkhalaf7892
Hello , Thanks a lot for the help. I have upload the file . Please if there was an approach I can fix this issue inform me how.
ahmadkhalaf7892
Hello I have uploaded it under the name Project located above please inform me if the solution was found
No RVT attached.  Did you press "Browse" next to "Attachment"?
ahmadkhalaf7892
Hello it is uploaded in the orginal message up . I have edited it
ahmadkhalaf7892
Yes I know that I am extracting solids from civil 3d to revit using dynamo . So the best approach would be to move the generic models to the elevation view ?
Also how did you check it and it was far how .
I mean what did you press so that you got this type of view in revit
Zoom to Fit and press Reveal Hidden Elements
ahmadkhalaf7892
Just if I may ask one more simple question how would I Get the northing and easting values in Revit ?
I don't understand.   Northing and Easting? Cartesian coordinates?  X,Y? That's exactly what Revit uses.
Spot coordinates
