Elevation Tag - Text too big
gballam
gballam
I've placed elevation tags throughout my project however the text is overlapping one other and from a distant it is not legible. I do not want to pull new elevations as I have already marked up the existing ones. Is there a solution to make the text smaller? I've tried messing with the settings but there isn't much to play around with. Please advise!
hmunsell
You should be able to edit the family and adjust the Label size to something a little smaller.
can you upload the family?
Howard Munsell
gballam
It's not a family since I got it from the elevation tab in revit itself (under view). I've tried to edit the text size but it there is not setting to change it.
gballam
Here is all i can see/edit. I changed it to 1/16" but that didn't do anything.
hmunsell
You're looking at the Elevation Type properties. The elevation family is a little deeper.
the family that needs to be edited is in the Project Browser.
Howard Munsell
gballam
wow i didn't even realize this was a feature. let me see what i can do with this info. thanks a bunch!!
mhiserZFHXS
Yea, family can be edited. But this is why we never have multiple elevations on the same marker.
