elevation refered to project and survey points
roberto.AconSegura
roberto.AconSegura
I need some object to show the elevation at a point refered to the project base point and the survey point. I know there are workarounds like creating two spot elevations of different types at the same point, one refered to survey and the other to project base point but I would really like to be just one thing.
It would be awesome to be able to use it in plan and section views.
Thanks a lot in advance,
jvpantin2
Indeed, you can modify a spot elevation tag to show both values at the same time.
Something like this:
¿Tu problema fue solucionado? Selecciona 'Marcar como solución'.
Así ayudas a otras personas a encontrar respuestas y agradeces a los miembro de la comunidad.
roberto.AconSegura
how?
