Elevation "Reference other view", Can I reference a Section View?
ndeioma9HYMZ
ndeioma9HYMZ
Elevation "Reference other view", Can I reference a Section View?  How?
Sure you can. You can't?  Are you checking Reference other View before placement?
....if you mean changing it after you place it, then no you can't.
ndeioma9HYMZ
When I check the refer to other view box, it only lists other elevations and drafting views.  I don't see any section views listed.
What View are you are you in?
ndeioma9HYMZ
In a normal plan view.
Yah, I'm not following, but use an Elevation to reference an Elevation and a Section to reference a Section.
You cannot.  Place a Reference View instead of an Elevation then you can pick the Section as the target.
