Revit truss family
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
mbiAK7WZ
754 Aufrufe, 9 Antworten
Revit truss family
Hello there.
i want to make a costum truss family, i have all parameters set for it, but the height parameter is not working after i have used array, do any of you have a quick solution to get the height parameter to work again and still be able to use array
Best regard
Martin
9 ANTWORTEN 9
Nachricht 2 von 10
als Antwort auf: mbiAK7WZ
Post the Truss Family.
Nachricht 3 von 10
You can leave the height alone in the family and attach the truss to a roof or a ref plane in project to change its height.
Nachricht 4 von 10
mbiAK7WZ
als Antwort auf: barthbradley
This is what i have at this moment, i have tried a few things but nothing worked for me
i hope you can tell me what i am doing wrong
the plan is the for every 2000mm there will come a new incline strut, and cant get the family to do the same thing as i want it to
Nachricht 5 von 10
mbiAK7WZ
Just posted the family
Nachricht 6 von 10
Couple of problems I see right off.
1.  The Left Ref. Plane is Pinned. Unpin it.
2. Linework isn't constrained properly to Ref. Planes.  NOTE: you can Align and Lock the TIPS of the Chords and Webs to intersecting Ref. Planes.  Tab-Select the end of the Line and you'll activate the end point. It's denoted by a blue dot.
Nachricht 7 von 10
mbiAK7WZ
i dont know if i am doing anything wrong but i cant get it to work
Nachricht 8 von 10
mbiAK7WZ
When i array the web lines, i cant get it to follow the chords height
Nachricht 9 von 10
mbiAK7WZ
i dont know what i am doing wrong and what i am not doing, i dosent seem to work when i lock the tips, and when i make the parameter to make one web line every 1400mm it makes 2 web lines and thay are made in 2 different arrays and with their own parameters
i hope you can help
thanks
Nachricht 10 von 10
Here's another approach that might be easier for you:  Use a Howe Truss and Attach to Top/Base Tool to attach the top of the truss to the bottom-side of a roof.
