Elevation marker disappears from plan view when Crop View is enabled (turned on) for that elevation
tomistrugar
tomistrugar
(Revit LT 2022)
For two of my elevations (N/S), if I enable (turn on) Crop View (for the elevation, not the plan view) their markers disappear from the plan view (see before and after screenshot attached). I have two other elevations (E/W) where this does not happen (see screenshot attached). Crop View for the plan view is disabled (off).
Why is this happening and how to stop it?
RDAOU
@tomistrugar
The elevation tag gets cropped and disappears because the Elevation markline is outside the Crop Region...The other 2 are not disappearing because they are inside the crop region
Either adjust the crop region
OR move the Elevation Line into the Crop Region
tomistrugar
@RDAOU Thank you but I forgot to mention that I already checked that, and made sure that all elevation markers were within the plan view crop region (see screenshot attached). So something else is causing the markers for two out of the four elevations to disappear?
tomistrugar
Another screenshot showing that the elevation markline IS within the plan view crop region.
Note: the outer rectangle shown in the image is the plan view crop region; the inner rectangle is my property boundary.
RDAOU
@tomistrugar
Open all elevation views and make Crop region in those views VISIBLE
Then make sure that the crop region in elevation view actually covers the entire elevation from basement to roof
If you look at the image below...the South Elevation (which is cropped) is missing in Ground Floor Plan (Level 1) because The crop region of the South elevation only covers Level 2 and up...
tomistrugar
Thank you @RDAOU, that was it. I didn't realise that crop region had to a. cover all the elevation marklines in plan view AND b. cover the levels you want to see them on in elevation view also. Screenshot of my South (like the North) elevation showing that the crop region was indeed not crossing the Ground plan view. Thanks again!
