IF statement for visibility
2 ANTWORTEN 2
Nachricht 1 von 3
Goran.JutrisaR5QUS
455 Aufrufe, 2 Antworten
I have two extrusion in one familliy and i would like to control their visibility.
so i created 3 YES/NO parameters:
   AB (instance)
   A
   B
The idea is when someone click checkbox (yes) on parameter AB then parameter A needs to be visible and parameter B not visible. and when someone click checkbox (no) on parameter AB then parameter A needs to be not visible and parameter B needs to be visible.
How should i write formula for this?
2 ANTWORTEN 2
Nachricht 2 von 3
RDAOU
als Antwort auf: Goran.JutrisaR5QUS
@Goran.JutrisaR5QUS
No if needed
Formula for A = AB
Formula for B = not(AB)
Nachricht 3 von 3
If parameter A is always going to be the same as AB, you could eliminate that parameter AB. Associate the visibility of each element to either "A" or "B". Then make B be the opposite of A, meaning A=(not B). If the user activates B, B will be visible and A will be invisible, and vice versa.
