Elevation border not showing wall line
semhustej
semhustej
I have a problem with my elevation view. In my print setup I "Hide Crop Boundaries" and setup all my elevations so that the crop border is aligned with wall or floor face. Some of the wall faces are not represented in elevation views when printed (I tried several PDF exporters). This seems to happen randomly, I can not find a reason why some walls / floors are not showing. See attached pictures. I am also attaching sample project.
Can someone help with this problem?
Tom
RDAOU
@semhustej
They seem to print fine at my end no missing edges/borders...used the built in PDF Exporter in 2022
Untick "Hide Crop Boundaries" in Printer Setup.
semhustej
Thanks for suggestions:
@RDAOU
Yeah, built in PDF printer works for me too. So it depends on the PDF exporter (I use Microsoft print to PDF and PDFCreator). So this doesn't solve the problem for me since built in PDF export has some other problems in my workflow.
I want to have crop borders not printed because of other views.
