What site is the best online schooling to earn a certificate in Revit 2021 Architecture? Thank you for any suggestions very much appreciated.
Solved by eosborn855. Go to Solution.
Solved by barthbradley. Go to Solution.
Solved by ennujozlagam. Go to Solution.
Solved by _Vijay. Go to Solution.
you can also check here Autodesk Academy free of charge. goodluck. thanks
you can also refer to this LINK and see if helps. thanks
https://certiport.pearsonvue.com/Certifications/Autodesk/Certifications/Overview
BTW: love your Avatar. Cool.
