Editting the View Range in the Properties for Floor levels
Hello
How do I edit the View Range in the Properties for Floor levels?
RDAOU
@Anonymous
You have a view template...you need to remove view range from that template
On the Ribbon...View Tab >>> View Templates >>> Manage View Template
  • Navigate to the view template named " Residential 1 " and uncheck View range
Unchecking the View Range gets rid of the View Range on the Properties tab on the left. I want to edit the View range, not discarding it away. How can I do that please?
RDAOU
@Anonymous
Unchecking View Range from template = Unlocks it  (ie: you will be able to change it from any view this template is applied to)
If you want to change it and keep it locked for the template ... do the following:
